were to set my amp settings?
i read that thing over and over....it says nothing of a low-pass filter ( how to set it that is)
and a subsonic filter.
and phase.....
any clue on what to do with any of these....or how and what to set them for.
A low pass filter will filter out all frequencies above what you have it set at. If you put your LPF at 100Hz, anything above that will not be sent to the speaker.
A subsonic filter is similar to a LPF, except anything below the subsonic filter will not be played. You should set this to the tone which causes your speaker to reach it's mechanical limits to prevent damage. For example, if your speaker is nearly falling apart at 20Hz, you should set it at about 20hz so that nothing below that will be sent to the speaker.
Phase shift is more complicated. The simplest way I can explain it....phase is the speed at which sound is transfered to the subwoofer. If you have it set on maximum, which on my amp reads as 180 degrees, once your LPF frequency is hit 100% of that frequency will shift to the subwoofer. On a medium setting the sound will shift over to the subwoofer without such a harsh transition, it will be partially on the speakers and partially on the sub. It's hard to explain somebody help me out...
i under stand....its the % of which you want the sub and speakers to play?
Do you have a seald or ported enclosure?
Where you set the LPF is determined by how well your speakers can play the lower frequencies, and how well your sub plays the higher frequencies.
Numbers to start are 20hz for SSF (ported enclosure would be a few hz below tuning) and 80hz for LPF.
OHHHHHHHHHH!!!!
ok.....i read that like 8 times to get it....
kinda like a fading type thing. got it
thank you for the help, i kinda got what you buys are saying now.
im going to have a ported enclosure tuned to 34hz and i think ill set the subsonic to about 25-28hz
and lpf....you guys recommend 80hz?
k12ug
MASTER MASTER
k12ug
FL
spoonraker
