O outa control Junior Member 3 0 Madison Mar 8, 2002 #1 were should i position the subs in my trunk so that i get the best sound inside and outside the car Click to read more...
U Unregistered Guest Mar 8, 2002 #2 Test for yourself. Every car is different so you should try one position and listen then try another and repeat untill you find the sound you want.
MxRacerCam 10+ year member Member 108 0 michigan Mar 9, 2002 #3 if your back seat has a pass through hole, try pointing them forward and venting them into the cabin. otherwise, face them towards the rear of the truck to slot-load them....
