went to my local flea market today
  • 4
d77543020
stockton ca
came up on some nice eclipse amps cheap eclipse pa5422 eclipse pa4212 still look new
well it keeps getting better i was just offered a matching Eclipse DA7122 mono amp i see its 2ohm stable anyone know if it could run at 1.3 ohms?
Eclipse was weird about rating their stuff past 4ohm mono. I had a rough time finding out what my 36501 put out at 2ohms on the sub channel. I guess you could always be the guinea pig, but I'm not very optimistic about it going close to 1ohm.
Nice finds btw
Nice finds btw
Nice finds btw
well im going to pass on it not gona be changing subs anytime soon
Your amp may have failed. A competent shop should be able to diagnose the issue in under 5 minutes either way. You didn't necessarily do...
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
d77543020
d77543020
stockton ca
d77543020
    May 24, 2024
    May 23, 2024
