Welding Wire Question
iSteven
I have a question. Today i was looking online looking for 1/0 wire for fairly cheap.
I Saw some true 1/0 gauge for 7 dollars a foot. Other then seeing that i thought ****. 10 feet 70 bucks. Then i saw through some things on google, welding wire. 1/0 Gauge welding wire 2 dollars a foot. And i actually need this stuff for is like the big 3 upgrade.
Can anyone tell me the pros and cons of using a welding wire on the big 3, and would this actually be good for amplifier wire also? Cause in a budget for 70 dollars i could get 10 feet of 1/0 power wire. Or for 70 dollars i could get Atleast 25 or so feet of welding wire. And looking at the wire compared, it pretty much looks like its the same thing with a different name on it.
For some people who might not want to read all of this, some people might not want to look at this all but i can shorten it easily.
Whats the advantage and disadvantage of using welding wire for the Big 3 Upgrade. And could welding wire be used for my amplifiers.
Yeah i am looking around. But 1/0 welding wire for 2 dollars a foot. If its good or just the same id just do that. Also a question for someone. I am not fully sure on all these gauges. is 4/0 gauge bigger then 1/0?
i use 2 runs of 1ah power and ground for amps and batteries its great solid works good for me i got it from local air gas place
All i needed was good reviews on the welding wire for me to do it. So far no ones said anything negative so i think it will be a good go for me to get some of this. Thanks man.
If Audio Technix still have the Blow out sale, get a 0 Gauge OFC Big 3 from them for $55.
http://www.caraudio.com/forums/audio-technix/576119-audio-technix-blowout-sale.html
Email Rick@AudioTechnix.com and ask about the big 3 0Gauge OFC Kit.
Yes 4/0 Gauge is so much bigger than 1/0.
There is also nothing wrong with running welding cables.
If Audio Technix still have the Blow out sale, get a 0 Gauge OFC Big 3 from them for $55.http://www.caraudio.com/forums/audio-technix/576119-audio-technix-blowout-sale.html
Thanks. Also very much thank you cause i need sound deadener the big 3 kits and some RCAs. I didnt know about that till you showed me that link.
Wireandsupply.com, get 2/0 welding wire for $2.43/ft. and 25 tinned copper lugs for $26 on eBay. The lugs are sold by the same company. I just upgraded my Big 3 using the products mentioned.
I run about 75 ft of 2/0welding cable+ 75ft of Audiotechnix 1/0. Welding cable is GREAT Stuff. Basically OFC. Only issue I have found (which isnt much of an issue) is that compared to "audio cable" you want to go up one gauge. Example, 2/0 welding cable is a bit bigger than most car audio 1/0, but 1/0WC tends to be a bit less. I prefer the former myself.
Also WC is not built to be used as car audio wire. Its not AS flexible, but unless your trying to make a 20degree turn with the stuff you will never notice or care.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
258
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
756
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
951
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
941
iSteven
iSteven
San Diego, CA
Durango03
    May 31, 2024
    May 24, 2024
