welding supply wire vs others...
So what's the comparison for? Just the wire gauge or quality of wire versus practicality?
wire = jacket + copper. so if you mean quantity of copper + flexibility of said copper when you say "quality" then yeah, this is is something like that.
It would be best if you can find out strand size and then number of each and you can compare area, which is what determines what gauge a wire is. Diameter can be deceiving just because very larger strands will have more air gaps and thus have a larger diameter. The smaller strands will be more tightly packed together.
For the most part Stinger and other reputable companies will devulge that information freely - others you need to research like you are. The welding supply stuff uses 30 gauge strands w/ neoprene jacket where most audio cables use 36 gauge strands and PVC. Neoprene is not as weather/oil resistant as PVC and the coper is not OFC. One reason our Kolossus Kable is tinned - it makes it marine grade and will never oxidize.
Oh and the KLM and KOL 1/0 are ~ 7/16"
very good info here...i have been trying to find the strand count of JL i found it for stinger and im sure its around for the kicker...i did not know about the WS wire so now i know is 30 ga but not sure how many strands...
i believe kicker is 4300 strands or something like that h.o lemme go check its written on the wire...
yeah, that is. With the price of copper I was wondering when wire mfg's would start using other materials.
FWIW - if copper is taken as the ideal conductor at a value of 100...Aluminum is about 60.
That's doesn't mean very much. The ampacity is more important when it comes to comparing aluminum and copper in power wires of equal size.
If you compare 2 1/0 gauge wires, for example, the ampacity of the aluminum wire is around 80% of the copper wire, meaning it can carry 80% of the current that the copper wire could.
Another useless bit of info - silver has better conductivity than copper, but I sure don't want to see what a 1/0 gauge run of silver wire would cost //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
photocrazy8
Probably doesn't like you
photocrazy8
CA
MustangGT25YRS
