hollowpoint
Hello all,
I am posting for a friend that has a weird whine noise through his tweeter when his engine revs. Here is what he wrote.
"I got a Tsunami Competition Capacitor.
I followed the instructions and hooked it up. (This was verified by a pro audio shop *** being correctly hooked up.) I reconnected my battery and my cap began to squeal, it then blew my 150amp inline ANL fuse. I quickly disconnected it and started my car.
Ever since that incident I have gotten static and squealing (that matches the revs) out of my tweeters. It also seems to have weakened my whole electrical system. My lights dim while rolling the windows down (even with my sound system off). My lights also dim much more than they used to while the woofer hits. The tweeters also output the sound of the CD spinning in the headunit.The problem only exists while the engine runs.
This is not your common alternator squeal. I have tried everything I can think of.
Since the incident I have tried changing all of the following:
* Head unit
* Spark plugs
* Amps
* Speakers
* 4 gauge Ground wires
* 4 gauge Hot wires
* Shielded RCAs
* Remote wires
* ELD
* Head Unit Harness
* Spark Plugs
* Alternator
* Battery
I have also tried:
* Regrounding both my head unit and amp straight to the battery
* Power the head unit and amp straight to the battery
* Run the power on the seperate from the RCAs
* Tried 4 different head units
* Ground loop isolators
* Ground Noise suppressors
* Upgrading to 120Amp Alternator
* Upgrading my battery ground terminals
The only thing that seemed to provide a band aid solution is on my Pioneer, if I touch the RCA ground to the headunit, the problem completely goes away. This does not seem to work on the Sony, Alpine, nor Pyle head unit.
Please I am begging for someone to figure this out. This was originally posted at CivicForums, but so far no one has solved it.
Crappy Video (HD coming soon):
Thanks"
* Head unit
* Spark plugs
* Amps
* Speakers
* 4 gauge Hot wires
* Shielded RCAs
* Remote wires
* ELD
* Head Unit Harness
* Spark Plugs
* Alternator
* Battery
I have also tried:
Thanks"
