weird voltage problem
is the ground nice and tight.my brother friend did the big 3 last year and he did not bolt down the ground to good. it was doing the same as u. i called him he said to tell u to check that first.
yea my bro friend asked me that. is there another battery? i said i dont think so. just check every thing. did u mess with your amps settings or radio? how u checking your voltage?
I did the big 3 today and my voltage stays at like 13.9-14 before the big 3 it use to stay at 14.4 what could i of done wrong?? i ran chassis to battery, battery to alternator, engine block to - battery.
What's odd here is engine block to battery. It should be engine block to chassis. Also, did you replace any of your original wiring or just compliment it?
When did you test the 14.4? Sometimes once it gets hotter through the day my voltage will drop a little bit, then from when it was the in morning when I started it up.
Also double check your grounds anyways
bassak47
bassak47
Chicago, IL
Racerx250
