Weird Speaker Noise
rtiid22
Hey guys, two nights ago I was blasting my radio for about 30 minutes to listen to it outside the car and now, every once in a while and my front right speaker would sound like a deep burrr.. like a horn sound of noise! This even happens when the volume on the radio is at 0. Any thoughts?
Check your ground, your RCA's and make sure your connections are tight.
DIDDO,,,,, you mighta rattled something loose when you were having the ol' outdoor concert show thing!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif it's probably something simple BUT if it's only that one speaker that does it then the problem "might" lie right there then.
Mine does the same thing occasionally last time i fixed it; it turned out to be the AMP ground. Just check that and the RCA's
rtiid22
rtiid22
Florida
Kastlez_
Mike Mccabe
