Weird noises.
what kind of upgrades to the system have you done? is it all stock? I wouldnt suspect a ground loop they typically happen at a higher frequency. but more info on the system would help.
What kind of LOC are you using with your stock head unit? Is it a cheap azz one without a ground wire? If yes, then the RCA's that are coming out of it are not grounded and are picking up interference.
I've no idea what you're talking about. I talked it through with the installation shop and they said to bring it in as soon as I'm in the area and they'll fix everything. See, I had a full system installed in my car in three days and then left to Ft. Carson Colorado. Never had a chance to iron out the kinks with them, and I kind of rushed the install.
Ubiquity
Ubiquity
Utica, Michigan
Ubiquity
