Weird noise from subs
Fordinator
Well I just got my new Audiobahn A1500HCT amp,wired it in to the bandpass ABP122T sub box,turned it on and looked sweet all lit up in blue,,but when the engine was started and the volume all the way down I'm getting a noise from the subs only,I unhook the rca's and the noise goes away.It's drove me nuts,,can't figure it out,,sounds good otherwise.I didn't have this problem with my Fusion amp but for some odd reason I do now,,any suggestions.//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
what head unit do you have? model#
And how do I do that,,If I might ask,,is it the wire around the rca connectors thing I saw in here.Still why didn't it do it before with the Fusion amp,,
I did remove the battery before installing it ,,and yes I have the fusion still tried it and it doesn't do it with the fusion,,but does with the audiobahn,,whats the pico????
the rca shielding is protected by a pico fuse on the pioneer boards...if you pop the fuse, you get noise.....the fusion may have an isolator built in to the inputs to eliminate noise on the shielding:idea:
Fordinator
Fordinator
New York
dman4486
vegang
vegang
