Weird issue...Need Help.2-XXX15(D2) LOW amp output..hmmm..Impedance is different
  • Thread starter HowLowd
  • Replies 0
  • Views 654
HowLowd
03 Max
Purchased two XXX's from 90accordman. Subs are dual 2ohm.
Installed them upon returning from afghanistan. Perfect. Ran a 1501d to each sub.
Pulled them to work on a plan for a larger enclosure with a big aero instead of slot port.
Speakers sat around for three weeks. Scrapped project as it was way too heavy. Even considering losing one amp and one fifteen to the other car for weight.
When i install them, i have nowhere near the same output, my 701 is still on the same settings and everything is still setup exactly the same. Upon meterig the subs, im pulling a 2ohm reading at the terminals. Pull the subs and im reading 4ohms per coil.
WTF?
HowLowd
03 Max
HowLowd
Fort Meade, Maryland
HowLowd
