Weird Electrical Problem and looking for a crossover.
bacardio69420
I had my system installed for over 2 years with no problems. Then one day i had a really high pitched screech out of no where. So I went to work trying to find out what the problem was and it seemed that my rear set of RCA's was grounding it self on the case to my Pioneer DEH-980bt. So i taped off all my RCA's. It fixed the screeching noise but then my subs started popping and everytime they did my amp would go into protection. Well i ran new speaker wire to connect my Kicker ks 6.5 components to he HU so that i would have some sort of sound and i tried to switch RCA's so that i would still have subs. When i did this my amp popped and started smoking really bad i blew the 4 channel section some how. I'm curious if anybody thinks my Hu might be shot. I sent the amp out to kicker ZX700.5 and i ordered new subs. I am goin from 10 cvr's to 10 cvx's. I am also adding my KX500.2, and a set of Kicker SSMB8's 8" midbass subs. If anybody has any imput on what might have caused this problem to start please feel free to enlighten me. I am also looking for a crossover to run the midbass between 80-450 hz my subs below 80 and my components higher than that. Audiocontrol is to expensive and i havent had much luck finding much besides them. I found an old Ma audio eq and crossover on ebay but missed the bid. Hopefully i will find something. And i also need some advice on what i should run for extra power for both of the amps, the zx700.5 is 90amps and the 500.2 is 70amps, I don't want to have to spend crazy money on a bunch of electrical work but i want to keep it at a consistant level. I have a 1.75 scorpion cap right now witch worked good with the 1 amp. If anybody could help me that would be great.
im having the same problem with the loud screech from my back right speaker when i disconnect RCA's the screech stops im also wondering if its the head unit i have a pioneer as well maybe its a pioneer thing mines a bit older its a pioneer DEH-P2900MP
after i put this i did some more research and http://caraudio.com/forum/wiring-electrical-installation-help/198477-engine-whine-ground-loop-fixes-take-two.html had the answer its the last one on the list about pioneer radios specifically having problems with their head units emitting screeches do to grounds and how to fix it
Thank you i am going to try grounding it when i get my stuff back from kicker. Since i don't have an amp right now i have speaker wire ran directly to my HU right now, when i turn it up a little past 3/4 it starts cutting in and out theres something wrong with my system somewhere, i have to sets of kicker rca's and 1 set of scorpion which are the ones that where giving me the problem. I am going to redo all the wiring all new kicker rca's and i am redoing all speakers with fiberglass enclosures on the door panels and custom kick panels. So hopefully if i do this grounding thing when i start i wont have any problems. Again thank you for replying.
bacardio69420
bacardio69420
Rochester, NY
bacardio69420
NorthFramingham
    Jun 30, 2026
