wats differnce between 2ohm4ohm
How many speakers are you trying to hook up to the same amp? Are they single or dual voice coil?
If you got one 4 ohm speaker and hook it up to a 2ohm stable amp, it just won't run a 2 ohm load. It will run a 4 ohm load.
Here is how you wire them.
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp=Dual+Voice+Coil+-+4+ohms+x+2&image.x=21&image.y=10
Be advised if you bridge your amp a 4 Ohm Mono load is the same as a 2 Ohm Stereo load. Make sure your amp is bridgable. OR DO NOT TRY AND BRIDGE IT.
Do not try to go to the 1 Ohm load unless you amp can handle it. YOU WILL BURN IT UP.
This web site should answer any question you may have. Take the time to look at all the links on the right side of the screen. There are over 100 different things to look at. USE IT
http://www.bcae1.com/
rustycar
rustycar
harrisville
pavengmike6
AJ (ACE)
    Jun 28, 2026
