Was a little impulsive.
Just bought this.... Good deal or not?
One complete xXx brand dual 15" sub package with amplifier
Wires and accessories included in box
2.5" 4 layer ASV coils
1500 max output power
4 Ohm impedance
High quality parts, high end subwoofers and amplifier
Great look
Everything is ready to go, just hook up the wires
Subs mounted into box already
Each sub has a 50 oz magnet
1500 Watt high powered 2 channel amp included
Dimensions: (L) 41" x (H) 19" x (D) 18"
FREE Extras Include:
Power/ground Wire (red & black)
In line Fuse
Connectors & Ring Terminals
Black Loom & Cable Ties
High Quality RCA's With Connected Red Remote Wire
Looks like a budget "all in one" deal to me.
While it probably wont do a hairtrick, I'm sure it will function. For how long?.... Who knows.
But for the love of god, install it properly. Read up on mixing sizes/brands of subs.
4 Ohm impedance
High quality parts, high end subwoofers and amplifier //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Great look
In line Fuse
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Also please don't run around telling people your running a 1500w amp. I don't care what your "package" says, your amp will not produce 1500w even if it was struck by lightning.
That will be the best/loudest that set up will do....
getting hit by lightning that is, not the system....
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
152
Don’t do it on the ground wire. If you lift the amps main ground and the amp tries to ground through the RCA cable shield, you can damage the head...
14
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
Steven Fuchs
Steven Fuchs
Brainerd, Minnesota, United States
TheUnderFighter
    May 20, 2024
    May 20, 2024
