Wanting 2k @ 2 ohm
Frank H
I am running a Sundown Audio X12 with dual 4 (version2). I keep reading this thing can take 2k+ all day (rated at 1500w but most say underrated). I have 1000w Alpine on it now and its very decent but wanting more.
What I want is 2000 RMS at 2 ohm BUT I want it to be 1ohm stable for when I decide the one 12" isnt enough, I can upgrade to two D4's and run 1ohm load to the amp and get more power.
Big 3 with 1/0g OFC wire, same wire to the trunk. Am adding a 2nd yellowtop battery when I relocate the amp's in the next week or so, since I have a spare sitting here. I will upgrade the alt before I run the amp at 1 ohm.
Recommend something to me please?
Hello I have:2 Alpine MRP-M2000 Mono subwoofer amplifier — 2,000 watts RMS x 1 at 2 ohms
Performance
RMS Power Output (Watts x Channels) 1500 x 1
Peak Power Output (Watts x Channels) N/A
Power at 2 Ohms (Watts x Channels) 2000 x 1
Bridged Power (Watts x Channels) N/A
Minimum Impedance Bridged N/A
Minimum Impedance Unbridged 2
Best Frequency Response 20-200 Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 102 dB
Input Voltage 14.4v
Features
Amplifier Class D
Low-Pass Crossover Frequency 50-200 Hz
Low-Pass Slope (dB/octave) 24 dB/oct
High-Pass Crossover Frequency N/A
High-Pass Slope (dB/octave) N/A
Bass Boost 0-12 dB
Bass Boost Frequency 30 Hz-80 Hz
Fan Cooled No
Fuse Rating 180
Speaker Level Inputs Harness
Preamp Outputs No
Width (inches) 20-1/4
Height (inches) 2-3/8
Depth (inches) 9-9/16
Features
Inputs: The amplifier offers both RCA line-level and speaker-level inputs for 2 channels. The supplied speaker-level input harness allows you to connect this amplifier to a receiver without preamp outputs; aftermarket or factory. The speaker level inputs will accept the output from a high powered radio.
Controls
Low Pass Filter: The amp has a low-pass filter, continuously variable from 50-200 Hz with a slope of 24dB/octave. This being a mono subwoofer amp, the crossover is always engaged.
Subsonic Filter: This amp utilizes a subsonic filter to eliminate super low frequencies that can rob power and damage speakers. The subsonic filter settings are 15 Hz, 30 Hz, and off.
Bass EQ: The Bass EQ circuit provides a variable boost (0-12dB) with an adjustable center frequency (30-80 Hz).
Connections
Left Side Of Amplifier:
GND (ground): gold-plated set screw terminal, accommodates bare wire up to 1/0 gauge
Battery: gold-plated set screw terminal, accommodates bare wire up to 1/0 gauge
Remote: gold-plated set screw terminal, accommodates bare wire up to 8 gauge
Speaker Output: gold-plated set screw terminal, accommodates bare wire up to 8 gauge
Note: Alpine recommends 1/0 gauge power and ground wire (2 gauge minimum is listed, but only if both power and ground wires are 1 meter or less).
Right Side Of Amplifier:
Line Inputs: 1 pair of gold-plated stereo RCA jacks
Speaker Level Input: Molex plug input for supplied 4-pin harness
Subsonic: switch; off, 15 Hz, 30 Hz
Phase: switch; 0°, 180°
Gain: rotary dial
Bass EQ Level: rotary dial; 0-12 dB
Bass EQ Frequency: rotary dial; 30-80 Hz
LP Filter: rotary dial; 50-200 Hz
How much ?
Frank H
Frank H
San Diego
mylows10
