want to be a little louder
that setup should get plenty loud with the correct box and wiring ect, what sorta numbers are you doing now? and what are you aiming towards? also is your box ported?
ported tuned to 33hz
it is loud but i would like to be a little louder
also i have no meter and do not know anyone in my area with one so i have no clue on what number im hitting
i would honestly like to do hairtricks more then loudness but imnot sure exactly how to other then tune low big box and lots of power
but i have little room and limited power atm
from what i seen they like alot more power then i have
are you saying 2 of them? if so i do not think 3 cubes each would be anywhee near enough for an 18 but im i will look into it and thnx
from what i seen they like alot more power then i haveare you saying 2 of them? if so i do not think 3 cubes each would be anywhee near enough for an 18 but im i will look into it and thnx
Thats not even much space for a 15".. Has anyone done a hair trick with 6 cubes of space?
factory alt
yellow top under the hood and 2 deka 9a31 or what ever they are called
thats why i said im not really looking to add more power cause i do not think it will handle much more then what i got atm
but i do not drop below 12.8 at the amp
i do not believe it is a dream
i was able to fit 6 type r's in my old blazer behind the back seat w/o a wall so i believe i can do something in here
was also able to do 2 15 inch mojos in there under the window line
so please do not crap on my thread w/o atleast giving a reason
? Two L7's 15's on 2000 watts not enough? something's not quite right with your set up or box. That thing should be super loud. I've seen a hairtrick on you tube with 2 12's.
This ^
Rethink your box design and get your electrical up to par. 2 15 L7's was doing high 40's in the back of a Traiblazer, and I believe you said yours is a hatch so you should get louder than that.
Is this box 6ft^3 before or after displacements? Even if it's after, that's still a small box for a pair of 15" L7's...any way you could fit a bigger box? Are you currently able to push the subs pretty hard, or do you think there's still room for more safe excursion?
pretty sure the aq is pushing them to the limits
also i understand what everyone is saying about they should be more then enough but what im trying to say is i still would like a little more
also 6 cubes before displacement thats why i was wondering if something like 1 18 would be more suited for my situation
treadburner
treadburner
st louis, mo
Flastrongman
