want broken amps or good amps
send me some money first and i'll send you a busted phoenix gold 4-channel you can play with.
model numba: xs-4600 its og
i have a pyramid 600 watt amp if you want picks or more info i can get it it turnsa out but doesnt fully transfer power turns on but wont turn subs on!
alpine m350
mono block amp very nice amp just wont come on and i dont know why...it makes me sad opened it everything looks perfectly fine, could be a very easy fix then you got yourself a 150 amp for 2 12"s or 2 10"s something....let me know i want to get rid of it...
Mike
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
148
410
jorgellyd
jorgellyd
columbia,sc
EMPIRE2000E2K
    May 16, 2024
    May 16, 2024
