Walk me Through installing PLZ
TheSpeakerMan
Knockin Pics Of da Wall
Im not to sure on how to install my stuff. Im going to put wut i think is right and u guys correct me where im wrong.
1st- Power Wire from amp threw the firewall.
2nd- Cut a short peice of it off to connect from the battery to the fuse holder. To Do that i would crimp the terminal ring and then crimp the fuse holder on the other end of the short piece of wire.
3rd-Strip off the end of the power wire and connect to the other end of the fuse holder.
4th- Then Take the peice of power wire coming out of the fuse holder onto a ring terminal and take off the nut on + battery slip on the ring terminal and then put the nut back on.
5- Cover the wire with that black stuff until it reaches wire hole. And cut of a peice of the black stuff to put on from the fuse holder to the battery.
If im not mistaking that should be all with the power wire.
1 Question is to crimp it means to tie with those tie things you get.
After that i get really lost. With the turn on wire and RCA and stuff.
Also im lost on which wires to use in each situation. I no which one is the power wire and that's it really. I got the knuconceptz kollusus 4 gauge wiring kit. Or maybe if some1 lives in the Little Rock Area they could help me out. The Wires i got are a blue long 4 gauge power wire. A short silver 4 gauge power wire. I dont know wut the short silver wire is for. The silver wire is about 2 ft long. A blue 12 gauge wire that has + on 1 side of the wire and - on the other. I was think that was to hook up subs. And Some blue wires with these plug with 4 plugs. 2 on each end. Im thinking this is my RCA.
1 more question what is the turn on lead? Plz help me out cuz im preety lost
I found out that the silver wire is the ground wire. Wut do u do with the ground wire? And the RCA's got a built in Turn on lead. Another ? is how do u connect wire onto the amp strip the wire?
I have the same wiring kit, and this is how it goes. Do everything you just said above, and place the wiring you ran from the battery into the B+ terminal on you amplifier.
The Ground: The short 2 feet wire is the ground, and that simply connects into the - terminal on the amp, and the other end gets an O ring and connects to any metallic location on the car (chasis). Be sure to remove all the paint of the metal to get the best connection possible. That takes care of the ground.
The RCA's: Take apart your dash and remove your headunit. Behind your headunit will lie a set of RCA oututs. Find the one that says "sub output," and match the colors, Red to Red, and White to White. Do the same on the amplifier, and that's the end of the RCA issue.
The Remore Wire: The KnuKnoceptz RCA's come with built in remote leads, it is located between the two wires that make up the RCA's. Look on the back of you headunit and you will see a wire harness. Find the SOLID BLUE wire and simply splice into it and connect the remote wire to it. You can use T-Taps or solder/heatshrink. Find the small post on your amplifier that says 12v and attach the wire.
That leaves the speaker wires, but if you don't know what to do with that, you shouldn't be doing your own installs....
That's all.
K thnx for the help
Above is the only thing i dont get. I got it but wut is the remote wire.
Ok i found the remote wire its the wire coming out bewteen the RCA's right. One more ? i dont got a 12V spot on my amp. 1 more ? on my speaker wires i cut it in half so 1 is - and 1 is + right?
Careful with that remote wire, its pretty thin and easy to rip.
12v just means positive.
It may be labeled "B+" or simply "+". If you still need help, post a pic of your amp.
Just look up a wiring tutorial on how to wire your sub(s).
Are you asking what the remote wire actually does? Thats what cuts the amp on when the keys on, and cuts it off when the keys off. It might say REM on your amp as well.
Ya it says REM on the other side. It also say Batt+ then REM then gnd
Batt+ is for power wires
REM is the turn on remote
GND is the ground.
One ? is how do i connect into the places.
TheSpeakerMan
TheSpeakerMan
Conway, AR
ssj2xxgotenxx
michigan born
    May 14, 2026
michigan born
    May 14, 2026
