Voltage drops??
mazda6i07
147.2db
I have an optima yellow top under the hood just a 1 farad cap in back. Im running MTX 9500 with an 81001 (check sig). Anyway, my problem is that when the car is running it will rest at 13.8, when i am playing music it will go no higher than that. And i drop to 11.6
What can i do to get at least 14.1 volts? Thanks
im running 2 batt's.
i sit at 13.9-14.1
when i play it sitting, i drop to about 11.6
if im driving about 12.5
sucks. and they dont make allot of " trust worthy" alt's for my car. so im kinda stuck till i find a go HO alt. if i can afford one.
Well, i just took off the cap, and it still sits at the same voltages as before. 13.8 and drops to 11's. So should i get 0 gauge and get a battery in back? Or just go with a hoa?
Do everything you can to get better voltage(within your budget). I had the same issues as you. I was running a Sundown 1500D at .5ohm with a stock battery and alt in a dodge truck...and I'd drop to about 11V doing test tones at full volume. Here's what I did:
1) Put a Kinetik HC2000 up front...+.6V
2) Put a Batcap 2000 in the back...+.5V
3) Upgraded my Big 3 from 4 gauge to 0 gauge...+.4V
3) Added some aluminum buss bars for my front battery...+.3V
Now I never drop below 12.8V when doing burps at full volume(even with a lot of clipping).
I have an optima yellow up front, but i may consider putting either a Kinetik HC600 or HC800 in the back. Which should i go with? How much more beneficial is the 800 from the 600?
Thanks
You'd need to go with HC1400-2000 to see any beneficial difference I think.
The only true answer is an HO alternator, though. You can also check out Excessive Amperage. And an HC1400 or 2000 is a good portion towards that HO.
Alright, ill give ohio generator tomorrow and get a quote, if they even make one for my car. :/
****, my little build is getting expensive. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
mazda6i07
147.2db
mazda6i07
Orlando, FL
missinglink
BP1Fanatic
BP1Fanatic
