voltage drops at 2nd batt
Is that with car running? And make sure to scrape the grounds and connection from pos to neg from front to back battery is a solid run. Crimping is all good and firm.
Installed a 220a ho alt, big 3, a kenetik HC 1200 blu, at the second Batt my voltage is 13.8-14.2 (i know that's kinda low my front Batt needs to be replaced, at the second batt it reads 12.6-13.0, thinking i need to Change my grounds, any other ideas?
How can the second battery read 13.8-14.2 and 12.6-13?
The battery I have under the hood was reading 13.8-14.2.
The battery in the trunk was reading lower at like 12.6-13.0 both tests while car is running
And yes I charged both batteries before hand,
Check if the battery is swollen at all on the sides
Where did you buy the battery was it used if it's used how old is the battery and was it charged regularly
When you installed the grounds, Did you scrap the paint off the metal until it's l a mirror.
When you upgrade + wires you need to upgrade - wires, power flows - to +
Mabey it hasnt fully charged yet, how long has it been in?
bumpingrandamgt
bumpingrandamgt
burtucky,mi
wew lad
