voltage drops affecting amp output??
lol runing over 4kw in sub amps alone, and i allready bought the 2k amp kentic batt just wana make shure its gona help or fix my prob ;-) somthing tells me ima need a third batt tho...
its a 120 amp stock alt and i have done big 3 with 1/0 also ran 2 lines of 1/0 from batt to amps..2 lines of 1/0 for ground also, thats about it///
trust me i looked into duel alts or a 250-300 amp alt but to change alts in a 07 pt requires you to pull engine and get a custom alt bracket made. ;-/ from what i hear most db comps have the car off n e Way and i plan on competing so i hope i can manage with added batts, i can add as many as it takes lol.....even considering a 16 volt system but not sure how to wire that up...
wow that sucks big time lol
that would inspire me to create a custom mount alt lol maybe weld it on top of the manifold
have the pulley sticking out like a supercharger lol J/K
guess im not doing 2 bad even with my almost stock electrical sys haha...got pulled over in my small town by a local cop an hour ago, and he told me they received 26 noise complaints in the past 2 weeks i been home lmao...
if you read all the posts, you would see i really want to run duel alts but its 2grand+ just to pull the engine make a bracket and install the second alt not even including the price of the alt(500). far as i know the HC2000 is only good up to 2k rms so im hoping another one will get me the same gains the first one did..;-) pushing low 150's at 10 volts haha i know im losen a good 500-1k watts from the volt drop./. what u guys think..
ptcruiser07
ptcruiser07
TX
ptcruiser07
