goingdef
Is that a agm deepcycle?i will be using 0ga for sure and the battery i have is the stock ac delco professional battery
4 AWG will work fine for your application, in stretches of a couple of feet good OFC wire can handle 150 amps of current, However 1/0 would be good if you don't want to come back later and redo it because you are upgrading your system.
u need an extra batt in the rear it will help with dimming
The Delco is a "Starting" battery. You need a good AGM or Gell Cell deep cycle up there that can take being drawn down quicker and charge quicker than just a regular cranking battery....I went through 2 or 3 before I went ahead and spent the $$ on what I needed.i will be using 0ga for sure and the battery i have is the stock ac delco professional battery
thanks i will do the big 3 first then upgrade batteries then maybe i can start on my headunit and door speakers...The Delco is a "Starting" battery. You need a good AGM or Gell Cell deep cycle up there that can take being drawn down quicker and charge quicker than just a regular cranking battery....I went through 2 or 3 before I went ahead and spent the $$ on what I needed.
Like everyone else said, a Big 3 and a good batt will help cure the headlight dimming. This is what I did on mine with a 1200 watt amp at one ohm. A Yellow top Optima is a good choice. And like others here will attest, if you have a problem with a Optima, you just take it to the nearest Napa/O'Rielley's/ABC/Autozone, etc. and usually do a swap with no hassle.
Do the Big 3 and see what happens...
there was a guy up here a few months back that found a online sale at advance auto he paid 150 online and then drove up to the store and picked it up, no shipping needed just pay online, but what one are you looking at mine was 190.00 with tax and it's the larger one if I'm not mistaken(g35)but still fits in my 02 corolla even though the website said it wouldn't?yikes $239.00 is what a optima yellow top battery cost what else do you guys suggest i am only going to be running the one amp thats all as far as budget goes i dont want to pay over the price for the yellow top so any help would be appreciated plus links help a lot thanks
