voltage drop
Ok, what amp is this? Do you have stock alternator and battery? Resting at 11.4 isn't good, but dropping to 8-9V while running is a whole different story. I'm surprised you haven't toasted that amp tbh. What size wiring are you running? Need a bit more info here. It's possible you are simply drawing too much for your electrical. In the meantime charge the battery and see if it will hold a charge. Did this just start happening and it was fine before, or is this a new install?
Audiopipe AP10001D, stock batt and alt, before I just had a Fusion 500 watt amp with 6 gauge wiring, now I have the Audiopipe 1000 watt amp running at 1 ohm with 0 gauge wiring. Before with the 500 watt amp it was fine, no problems but of course 500 watts doesn't demand much.
mr.gaf
mr.gaf
Shreveport, LA
Kingstroker
