viper 5900 wiring
toyotamobbin
So i decided to install my viper 5900 without the remote start feature because i drive a manual and don't have the necessary modules of make if safe, and i am wondering if i need to hook up any of the heavy gauge wiring coming off of the satellite relay box as they appear to be for the remote start interface. On a side note im not currently planing on hooking up a starter kill,if that is what the wires are for.
If you aren't doing R/S or starter kill (which make sme wonder why you got the 5900) then yes all you need is ignition.
And you wont even need the box or heavy wire, you can pull it out of that ribbon harness connecting the brain and relay pack. It will be the pink wire.
피크를 사용하지 않을 계획입니다.
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
84
358
352
toyotamobbin
toyotamobbin
wenatchee wa
qkassidyw
    May 16, 2024
    May 16, 2024
