viper 5900 wiring
toyotamobbin
So i decided to install my viper 5900 without the remote start feature because i drive a manual and don't have the necessary modules of make if safe, and i am wondering if i need to hook up any of the heavy gauge wiring coming off of the satellite relay box as they appear to be for the remote start interface. On a side note im not currently planing on hooking up a starter kill,if that is what the wires are for.
If you aren't doing R/S or starter kill (which make sme wonder why you got the 5900) then yes all you need is ignition.
And you wont even need the box or heavy wire, you can pull it out of that ribbon harness connecting the brain and relay pack. It will be the pink wire.
피크를 사용하지 않을 계획입니다.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
116
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
187
399
373
toyotamobbin
toyotamobbin
wenatchee wa
qkassidyw
audiobaun
    May 19, 2024
    May 19, 2024
