viper 5900 install
technically yes, but if you leave it in gear the vehicle will take off. If you can find your neutral safety switch you could use that for the safest way.
I don't know if it has one, I still have to push the clutch in to start it when its in neutral. Ill go look threw my schematics. Also where would be a good place to mount my proximity sensor? i was thinking of putting it up by my dome light.
If its a proximity sensor then you want it in the middle of the vehicle on the flooorboard (or as middle as you can get it.
If it is a shock sensor then you want to ziptie it to a harness and adjust sensitivity accordingly.
toyotamobbin
toyotamobbin
wenatchee wa
THUNDERBIRD
