Vibrations On Box !
mcfly129
Hey I just bought the 2 kicker comp vr 12s in the kicker box. I mounted my amp to the back with 8 screws whitch is 2 on each side. How ever when I turn my system loud I get a vibrations that is coming from my amp. I push the amp tight against the box and the vibrations noise stops. If I let the noise keep going the subs start to like rattle but then again if I hold the amp in tight it stops or push on the middle of both subs. I dont no what to do im about to go nuts. I thought it was my lpf and hpf or crossover doing it but idk any more //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif . Can some one please help me and tell me what I can do ?
Thanks very much......
Well I have the original screw holes that I screwed the amp in before. I dont have any open holes.
Im thinking about taking the amp off and mounting it to the back of the seat whitch would most likely solve it I think .
How should I seal the holes ?
Well in a couple of hours I will try to hook the amp onto the back seat if the amp fits on there ill mount it to it if not ill just move the box back like 5 inches and screw it into the trunk floor aswell as the box itself. I didnt do that yet, then ill see if it makes a differnce. I hope it will it should...
What do you guys put your head units hpf and lpf on. I have 0,78,125. I have no clue what to put it on I was thinking 125 for hpf 78 for lpf what do you guys think.
And should I use washers and if I should what kind should I use rubber ones ? I know im not sopost to put metal ones on .
mcfly129
mcfly129
Florida
mcfly129
