Hey guys..
I'm not sure how to trace this down.. I'd like to not pull the headunit and console out for the 25th time now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.. All wires are solid,.. just redid a new harness.
Here's the deal.
Had a Pioneer AVH-P4100DVD after I installed my "system" this past week.. and no issues in the system that I could tell.
The AVH died from me banging too hard on some panels.. my fault.
So I replaced it with a Kenwood DDX 470. Love the new headunit.
But few minor issues.
1) Just to test.. I put the volume on zero and rev the engine and a VERY VERY almost inaudible amount of whine comes through the speakers.. Nothing you can hear even with the volume on 2.. it's that quiet. Your suggestions for removing this? Even if it's installing noise elminators/ ground loop eliminators.
2) The car would shock me randomly when I was getting in and out yesterday. Then last night it didn't shock me at all for 2 hours of fiddling around with the new headunit. While it could be static elec.. this car has never shocked me before.
Not sure where to track this down..
Something I did notice.. was the headunit wouldn't power up when I was installing it until I put the antenna lead in. Which makes me think the headunit is at least using the antenna wire as a second ground , if not initial (I do have regular ground going to it as well).
If the headunit shouldn't power up without the antenna lead in it.. then it has no bearing on this.. just thought I'd mention it.
My ground (amp ground) is bolted to a factory bolt in the rear sheetmetal where a child safety hook was.. that I removed all parts but the bolt , added some washers,.. and then ground it down tight with 4gauge ground. I don't believe this would be the issue.. it's a solid ground,.. but thoughts?
Electrical demons are a bit difficult to track sometimes.. So I'm more looking for some solutions that don't involve essentially rewiring everything, maybe to no avail. IE: Can I ground the headunit itself for a redundant ground of some sort that may help this?
With the ground loop/noise suppressors -- Will one work , or do I need 3 of them (one for each set of rca's ? ).
Oh, and to pre-empt a possible question. The shock feels like a strong static electricity shock.. touching the door handle or something.. then you don't get shocked anymore of course. It's not where you put your finger on the car metal and feel a constant "shock/buzz" sort of thing.
I put my meter to the car metal and chassis in a few areas around the car.. and it read 0.0 -- Not sure if that would really pick anything up.. but just did it anyway to see.
Thanks
Thanks,
Here's the deal.
Thanks
Thanks,
