Ok,.. so run it down and out to the kick panel area or so.. and find a nice piece of metal and bolt it in?
I could run it to the battery if necessary,.. but surely that isn't.
Sounds to me I should do this in progression.. The wiring is very sound when I did it originally,.. so if this headunit doesn't have a ground and is grounding through the antenna and who knows what the exact path is.. Then adding a ground via speaker wire down to the sheetmetal on the floor should clear it right up. But, it's not a big deal to run it back to the battery if that is necessary.
You ran a separate power wire , bypassing factory wiring,.. to your headunit (like an amp I suppose).. and then grounded on the floor of the vehicle.
Just if I wanted to entertain the idea of "isolating" my headunit,.. can you give me specifics on the relay to buy (link?) -- and exactly which wires to run to it?
I see the diagram -- so this is how I'm interpreting it..
You ran a "yellow" 12v constant on from battery to relay and spliced that same wire to the headunit as the "Yellow" 12v constant power. You Ran a ground wire from headunit to floor, and spliced it mid stream to the relay as well. Then you used the "red" wire (which I used to think was the 12v constant.. but it's the ignition wire) and ran it from the factory harness to the relay, and then out from another connector on relay to the headunit. That about right?
Doesn't sound too difficult,.. think I should go with that model and isolate the HU,.. or just ground down to the floor and that's all?
I sort of thought noise would always be a result of the RCA's picking up EMI.. Is this still the case? Bad/no ground causes the RCA's to pick up noise? Cause that's where the HU is feeding the signal to everything, and with a Ground Loop Eliminator in line on the Sub RCA's it eliminated the noise completely. (But it's a bandaid in my book.)
