vaccum sealed?
I'm probally wrong here but I would think that would be nearly impossible to vaccum seal an enclousure....because of how a speaker is made. Most if not all magnet structures are vented...and to get a perfect seal around the mounting ring seems iffy...As far as a good air tight box build...with little air loss ...i've heard it does help low end extension...if completely sealed vaccumed out ...i'd think it wouldn't perform as well because sub couldn't perform once sucked in...
Hmmmm.
What an enclosure do for a speaker? It creates an air cushion behind the spekaer to work as a suspension, tuning the overall system and dampening cone motion in the process.
How does this work? It work by air molecules inside the enclosure. When the cone move in, the space inside the enclosure gets smaller (by cone taking up more room), the box is 'sealed' so the air molecules have no where to be displaced, they simply squeeze together tighter (tighter than ambient air prssure outside the enclosure). This compressing effect on the molecules now means there is a high pressure zone on the inside side of the speaker's cone, and a low pressure zone on the outside. This makes the cone naturally want to move back out and equalize pressure on both sides of its cone. Simple physics. When the cone moves out, same thing only in reverse... air molecules expand apart creating low pressure inside the box and high outside, again wanting to cetner the cone back to neutral.
Now, remove the air molecules from the box. Your air spring/cushion has just been removed, enclosure 'tuning' just went right out the window. Due to having low pressure inside the enclosure from ******* a vacuum, as was said above, the cone would simply **** in and never move back out. This would hurt performance, not help it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
And I agree with above, even if it were a good idea, building an enclosure so sealed it didnt lose its vacuum... would be almost impossible. Even the wood ifself would need to be sealed.
Well... i was just thinking about what you guys are talking about.. and if you were to wire it out of phase, so the cone moves outward instead of inward.... it would be pretty neat... or mount it inverted
You seem to be a bit confused. The speaker's cone is intended to move in AND out. Now, if someone sucks a vacuum that pulls the cone in permanently (until vacuum is released), how is that so neat? Inverting the speaker or wiring it out of phase wont help, at all.
******* a vacuum inside a speaker box is not only a horrible idea, the speaker would fail to even work anymore. Give it up guys, its just not a feasable idea, nor can anyone even tell me any sort of theory of how this would help... anything. Cuz it wont. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Might as well discuss ******* a vacuum in your CD player and the performance improvements involved....
we need pics of this...if you sucked all the air out of the box, the sub would just **** in it self, it would just bottom out and stay there
not really. On the inside of the box the amount of air should stay constant. The volume is what's changing. A sub is trying to create a alternating low and hi air pressure area, but that's far from a vacuum. I'd say most of this is coming from people wanting to correlate the words "sealed" and "vacuum" together.
//content.invisioncic.com/y282845/emoticons/waycrazy.gif.f4a380c3f94043939fd369defd9e6be2.gif
......someone doesn't quite get the concept of how a sub works WITH an enclosure and in respect to the volume of confined air within said enclosure. This by far has got to be one of the siliest posts to date.
please copy and paste audioholic's post to microsoft word, print it out, then go to the12volt.com and read.... when you think your 'friend' understands...then read some more.
thank you and have a 'vacuum enhanced' day!
toolfan89
official ca.com shemale
toolfan89
your moms cooter
monkeyboy
