Using Power from fuse box
tehon3299
How can I "split" a fuse in the fuse box...For example, how can I run my radar detector wire to the fuse box instead of the battery for power WITHOUT just shoving the wire behind the fuse? I had a fuse looking thing that plugged into one fuse and had a spot for 2 fuses on it but it doesn't work with the mini-fuses.
Check out http:\\http://www.partsexpress.com they have the adapters for all different kind of fuses. Or you could pull the fuse panel and hard wire it to one of the empty terminals on the back if you have any. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
tehon3299
tehon3299
Liverpool, NY
ramos
