Using cca wire for grounds
  • 6
Was adding more grounds and run out of ofc wire, and I have plenty of cca wire didn't know if it would work, just for grounds?? What kind of difference it would make, have on car audio ??
I don't think you'd hear a difference...but if the other grounds and power wires are done in copper, I'd do the rest in copper..
Aluminum has a higher resistance so you'd need to go at least one size bigger to get around that...and Aluminum also corrodes faster so you'd need to change it out sooner
If you have a bunch of it, use it. But just be very aware that you need to use more cca in comparison with copper.
I had cca from my rear battery to the amplifier ( about 30 inches of positive and 24 inches of negative) and had a .7 volt drop between battery and amplifier. Changed to the same size of copper and now have a .1 volt drop.
Id run OFC all or none. CCA corrodes much quicker and takes a much larger size and strands to meet the OFC sizes as stated. I wouldnt recommend mixing your wiring. It could create several issues in the future
702
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
573
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I hold firm on the deposit in all situations 😎
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know. Cheers !
998
bernee69
bernee69
NC
nauc
    May 12, 2024
Brendon Jenness
    May 11, 2024
