poolman966554
I think this guy has to be trolling.. otherwise hed listen to advise.OK so school me.... if you dare
OP run the fuse the amps rated for. simple as that.
If for some reason your popping fuses, then ensure your ground connection is properly grounded/tight.
Use a DMM to set gains on the amp. you 'could' be clipping the fu3k ouuta it
