Upgrade questions
Paul73
I am planning another build and would like you guys opinions on electrical upgrades, Car is a 1988 Thunderbird Turbocoupe. System will include my Sundown 1500D running two Avalanche 15s @ .5ohm (this particular amp benched 2200rms at that load) Sundown 100.2 running unknown 8s in front floor pan and Sundown 100.4 running active mids/tweets.
I already have a 200A Powermaster alt. and plan on doing Big Three with at least 2ga. Idea was to run two yellow tops, one up front and one in the trunk but I wonder if this is the best set up. The car will basically be a weekend play toy not so much a daily driver per se but I would like it reliable.
Opinions on this setup or suggestions for changes welcome...
A extra can't hurt. 1 up front for car, mids / highs . 2nd in back on sub amp only.
The batteries will see each other still but having the one straight to the subs will damping the draw from the front a little. When I do an install with duel batteries sometimes I try both ways . 1) I run one line 1/0 from alt to front battery then to the back battery. 2nd I try from the alt 1/0 to the front battery then 1/0 from the alt to the back. I have had some better results with # 2 cause it is pulling 2 loads from the alt at once rather then one. It uses the same amount of wire so it dosen't cost to see. Hope it helps
MLA
Paul73
Paul73
Hampton, VA
missinglink
