Upgrade electrical, where should I start?
xmakeafistx
I've been wanting to be able to run woofers that can take a lot of power, but obviously this requires upgrading electrical.
I'm running completely stock so far, just a stock 90 amp alternator, no extra batts.
Basically, I want to know the best ways to upgrade my electrical without having to purchase an H/O alternator if possible. The prices of alternators makes me cringe..
Which also brings me to another question (sorry if its ridiculous), would it be possible to run two stock alternators? Would it be less expensive than buying one H/O alt? I've been looking at places & I've been seeing stock alternators for cheap..
Also, what kind of batteries should I be looking at?
I want to be able to run about 2000 some watts, but not above 3000 really.
Any suggestions? I am aware I am being very general, and that I'm pretty nubby when it comes to all of this.
Thank you all in advance for any help.
I was wondering about this too
OP just bite the bullet and get an HO alt now. You'll save yourself from future headaches from potentially blown equipment and you'll also be ready for a larger setup when you get the itch to upgrade.
I generally wouldn't run more than 1200-1500 watts off stock electrical depending on stock alt size (and yours is small so consider yourself at the low end of that spectrum).
By the time you buy a dual alt mount and stock alt, it will be pretty close to the price of an Ho alt.
pretty much
you can do that and it will work just fine, but you need to make or find a bracket that each of the alts can mount on, the belt size will change and the engine idle might need to be adjusted to account for the longer belt and another pulley for the engine to run. but yeah usually by the time you put all the work in you end up with about the same price as a ho might save a few bucks for the added effort, just depends on prices. I'm not sure whether or not performance would be better/worse at idle.
too much work and money to do it that way. db electrical has some decent alts that are fairly cheap. sorta like the audiopipe of alts
lol then dont buy anything comparable to audiopipe...sry not hating on you just audiopipe itself ***** balls and thats a whole nother story....
ok from my experience i have ran 1200rms on a 80amp alt for 3 years stock wiring everything just one run of 0g into 4g to my two amps i was told long time ago that roughly each 1000rms u need 70 amps just as a rule of thumb so thats just some food for thought
also the easiest best thing for you to do is to upgrade all your power wires and do your BIG THREE! and then work from there maybe a better battery before u get a new alt and such
Yeah, I am obviously going to start at the big 3. Probably the first step I should take..
I don't know, I see everyones point about buying the alt because that will be what I need most, but just seeing how much money spent at once makes me cringe.
^^^ This. Unles you're really good fabricating metal you'll pay more for dual alternator mounting than the HO alternator itself.
IMHO you should be OK with a couple good AGM batteries and stock alt. Of course this will depend on what amp, what impedence, and your listening habits, but 1 battery per 1000w has been a safe bet for me. You can get away with less probably but batteries are cheaper than 2000W amps.
xmakeafistx
xmakeafistx
Kenosha, WI
dipitydoo
