Understanding a few h.u. settings
set lowpass to 80-100hz, but if u have it on hu turn it off on amp.. if it has hp for other speakers set that at 100 and u can go up if u need to (my fronts at 120 rear at 150) my amp doesnt have a off on the lp over i wish it did i'd like to use lp on hu., so again if u have hp set on a amp turn it off if using one on hu... set everything with hu at about 80% volume, if u run a hu that goes to 35 at 35 u will clip something so i don't go past 28 sometimes 29..
Ok. I believe my head unit goes to 62. Yes the head unit has high pass filter as well. Thanks guys
k so try to keep it below 50 should prevent most clipping if u adjusted amp gains down to 25%, and u dont use bass boost or pre set eq and have sub volume on 0., once u get it set up right u can adjust 1 thing at a time and try different lp,hp settings and hu sub volume i adjust that up when i play rock and back down when playing re bassed type songs
Let's if i can give my input too. 180 Watts is the maximum power your speakers can handle. And it is 4 ohms. And you're trying to find the...
27
4K
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
I found this, can it be done with snapon modis ultra scanner which i have...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
743
My63bug
My63bug
Vacaville ca
BOOMINGRANDPA
