Understanding a few h.u. settings
set lowpass to 80-100hz, but if u have it on hu turn it off on amp.. if it has hp for other speakers set that at 100 and u can go up if u need to (my fronts at 120 rear at 150) my amp doesnt have a off on the lp over i wish it did i'd like to use lp on hu., so again if u have hp set on a amp turn it off if using one on hu... set everything with hu at about 80% volume, if u run a hu that goes to 35 at 35 u will clip something so i don't go past 28 sometimes 29..
Ok. I believe my head unit goes to 62. Yes the head unit has high pass filter as well. Thanks guys
k so try to keep it below 50 should prevent most clipping if u adjusted amp gains down to 25%, and u dont use bass boost or pre set eq and have sub volume on 0., once u get it set up right u can adjust 1 thing at a time and try different lp,hp settings and hu sub volume i adjust that up when i play rock and back down when playing re bassed type songs
My63bug
My63bug
Vacaville ca
BOOMINGRANDPA
