Underseat Speakerbox for 2005 Yukon
  • 2
lurchy
Fresno
So I am going to give my son my 2005 Yukon for his 16th b-day and I wanted to put a sub-woofer system in it to surprise him.
I am thinking of keeping the stock 6 cd Bose Head unit...But getting the PAC audio adapter to add an aftermarket amp and put two 10's in a box in the back.
I saw this Enclosure on Ebay for only 117 bucks. (Item # 310514077435)
Seems like it would fit nicely....here are the specs
AIRSPACE: .60 CU.FT. PER CHAMBER.
MOUNTING DEPTH: 4 1/2"
MAGNET DIAMETER NOT MORE THAN 5"
CLEARANCE UNDER BOX: 1 1/2"
View attachment 26539636View attachment 26539635View attachment 26539634
So I was looking for some inexpensive 10" low profile woofers that are less than 4.5 inches mounting depth and was looking at a pair of Rockford Fosgate R2SD4-10 woofers for 110 bucks for the pair.
These woofers are rated for a minimum of .50 cubic feet and a maximum of .75 cubic feet for sealed boxes.
I am looking at getting a 300 Watt RMS mono amp (at 4 ohms) to push these. The speakers are rated at 200 RMS each...so I think 300 watts should be enough? Or would the amp get too hot? do I need upwards of 400-500 RMS?
I am trying to stay under 300 dollars and this setup looks to be right at that mark.
Anyone have any advice or suggestions?
I think this will more than suffice for the kid....I know its cheap...but not going to spend more than that.
Looks good. I can sell you a way better pair of brand new 10s for not much more cash than the fosgates. If your interested.
My main issue is the shallow mounting requirements and trying to keep everything under 300 bucks....thats the budget the wife gave me :p
I am wondering if 300 Watts RMS mono amp is enough to push the fosgates...
Very true, however I also am having trouble finding a speaker that would appear to fit the bill, several have tweeters and a woofer, but not a sub...
52
7K
That's a fukking triangle not a multi-dimensional wedge. You are a funny kid. Why not do it with a pentagon or octagon?
14
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
668
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
976
https://www.sonicelectronix.com/ci95-2005-buick-lacrosse-wiring-harness-to-install-a-new-car-stereo.html?sort_order=price_asc lots of options...
lurchy
lurchy
Fresno
Dtrom
    May 18, 2024
    May 18, 2024
