Type-x
a loose coil cant be fixed....what you should do is take them out of the box play a 20hz tone on medium volume and see if the subs are making the same noise.....if not then it could be an air leak around the sub or in the box...
I took I out of the box and it's deffinitly the coil is there a way I can run the sub around it like to the the other coil I'm gonna test it with a multimeter and see if either one is bad
QUOTE=Imtjnotu;8080901]a loose coil cant be fixed....what you should do is take them out of the box play a 20hz tone on medium volume and see if the subs are making the same noise.....if not then it could be an air leak around the sub or in the box...
yeah, you can't just bypass the coil because it'll still make the noise. I had my 10 rebuilt by Corey Dean @SPLaudio and it is bangin in my truck on around 1200 watts daily.
---------- Post added at 07:30 PM ---------- Previous post was at 07:29 PM ----------
^^^ Price was great on the rebuild btw
Yeah I'm out east on long island and theres not many people around here
That could rebuild it for me
[quote name='skylineTT']yeah, you can't just bypass the coil because it'll still make the noise. I had my 10 rebuilt by Corey Dean @SPLaudio and it is bangin in my truck on around 1200 watts daily.
^^^ Price was great on the rebuild btw[/QUOTE]
IM really not sure what it is I know how to wire subs and amps
I went to school for wiring just never learned about the subs themselves
I've had this problem with other subs it makes a clicking noise when the
Sub flexes more and the power surges it's fine with long tones but when the
Tones are Short it clicks
looks like i have made a few of these //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
they make a excellent sql woofers, all they need is the proper soft parts....
Thedirtydan
Thedirtydan
Long island, ny
RangerDangerV2
