djman37 5,000+ posts SOLID 8,521 28 DFW, TX Nov 16, 2005 #46 mikey, I have a box you can use to test with. 1.85 each side, tuned to 32hz.
OP mikeyboc 10+ year member CarAudio.com Veteran 2,363 0 Sugar Land, TX Nov 16, 2005 Thread Starter #47 Yes, DMM and 50 HZ tone. I read some not so good things about setting gains with a -6db tone. What is the impact it would have?
OP mikeyboc 10+ year member CarAudio.com Veteran 2,363 0 Sugar Land, TX Nov 16, 2005 Thread Starter #48 mikey,I have a box you can use to test with. 1.85 each side, tuned to 32hz. Click to expand... What are the exterior dimensions? I need to make sure I can fit it in the trunk. The trunk is decent sized, but the opening is considerably smaller.
noob with an RS 10+ year member i poop on you 3,821 8 earth Nov 16, 2005 #49 Yes, DMM and 50 HZ tone. I read some not so good things about setting gains with a -6db tone. What is the impact it would have? Click to expand... it will be a helluva lot louder without clipping. (assuming the signal isnt clipping right now)
LuNaTiC 10+ year member 18 to make up for below. 1,601 1 MA Nov 16, 2005 #50 wait till night, take sub outta box and shine a flashlight in that thurr box and look for de light poke thru.
djman37 5,000+ posts SOLID 8,521 28 DFW, TX Nov 17, 2005 #51 What are the exterior dimensions? I need to make sure I can fit it in the trunk. The trunk is decent sized, but the opening is considerably smaller. Click to expand... 40 wide by 15 tall by 20(or 22) deep
OP mikeyboc 10+ year member CarAudio.com Veteran 2,363 0 Sugar Land, TX Nov 17, 2005 Thread Starter #52 I appreciate it, but that bad boy is not going to fit.
N Nukedsodapop 5,000+ posts CarAudio.com Veteran 6,072 41 Somewhere Nov 17, 2005 #53 watch the phase, Im not gonna read this whole thread but that could be a problem
trow100 10+ year member F*ck *** get me a beer 538 4 CT Nov 17, 2005 #54 If your back seat is lined with metal instead of just sutffing might be the problem for the large decrease in output when u put them back up. Metal blocks out a lot of frequencies..any one correct me if this is wrong
