Type R Enclosure
old_greg
I have two type R 12's 2ohm
Running them with the Apline V-power Mrp-m1000
When i bought these guys they came in a sealed enclosure(Not gonna work)
Gonna have a ported enclosure made
ive been told 32Hz is what i should have the port tuned to
Are there any other Hz that could work better or is this good?
I'm working on the same thing. I have a LS400 with the gas tank/firewall between the trunk and rear seat. So, I'm going to port into the cabin via. rear deck. These are the numbers I came up with.
Conversions:
vent or port diameter (dv) = 5 inch = 12.7 centimeter
number of ports or vents (Np) = 1 = 1
enclosure box volume (Vb) = 2.6 foot^3 = 73.6238011392 liter
port or vent length (Lv) = 18 inch = 45.72 centimeter
end correction factor (k) = 0.04837306723224 = 0.04837306723224
Solution:
tuning frequency (fb) = 33.377500089617 hertz
Mind you I'm working on a 4th order bandpass.
I have two type R 12's 2ohm Running them with the Apline V-power Mrp-m1000
32Hz is fine
old_greg
old_greg
Philadelphia, PA
amp roach
