type r 12 or re se12 single sub setup
yessir
SE handles more power and has better SQ, but they both get very loud.
The SE might go lower than the SR.
Im very happy with the SR. Only reason Im considering selling is because I might buy a 15" Dayton DVC. I dont know yet (dammmn caraudio addiction!)
lmao meng i get it now! im slooooow
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thats how ya gotta ride......
slooooow and looooow
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yea i know what you mean! i keep replacing subs cause im not satisfied, im probably gonna have to upgrade my sub amp, which has performed surprisingly well, Its an infinity ref611a that puts out 657 watts at 2ohms. I cant even get this thing to get hot on me, but i think i might need more power in the future. If i were to get two 4ohm dual voice coil subs and wired them parallel (or is it series?) to achieve a 2 ohm load how much power would each sub see? im kinda confused on whether the power is split or not, i figure if you wire the two together you basically have one speaker that would both get all 650 watts. am i wrong?
you will either get a 4 ohm or 1 ohm impedance from you amp when wiring two dual 4ohm subs together
so what do i need to get to get a 2ohm load? One 2ohm sub or Two 4ohm single voice coil?
you need either:
a single 2 ohm sub
a dual 4 ohm sub wired parallel
two single 4 ohm subs wired parallel
two dual 2 ohms subs wired series/parallel
678
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
797
Dammned that looks awesome. be a great picture in a workshop!! I have maybe 6 steel ratcheting type clamps, if that. much like the ones you have...
864
If you want something weather resistant, get a marine amplifier.
00 durango
00 durango
Fresno Ca
Slammed
