I am planning to run this:
Specs:
4 x 150 Watts RMS at 4 Ohms 4 x 300 Watts Max at 4 Ohms
2 x 600 Watts Max at 4 Ohms Bridged 4 x 250 Watts at 2 Ohms RMS
MOSFET Automatically Switches to Maintain Rated Power Over a Wide Range of Battery Voltages
Stiffly Regulated PWM-Type Power Supplies
Variable Input Level Controls for Each Pair of Cannels
Variable High & Low Pass Crossover Controls
High-Efficiency, Heavy Aluminum Heatsink
Remote Subwoofer Bass Control
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohm Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Power & Protection LED Indicators
Advanced Protection Circuitry
Soft Turn On/Off
Frequency Response: 15 Hz-35 kHz
S/N Ratio: 90 dB
Dimensions: 10.25''W x 2''H x 17''L
with two of these:
Specs:
Model T5512-44
12" Subwoofer
Dual 4 Ω
30 - 150Hz
RMS power 300
Rec. power 150 - 300
Or, this:
Specs:
# of Channels 1
Class D
Amp Type Optimized for Subwoofer
Full Range
CEA-2006 Primary Ratings RMS Power @ 4Ω 300 Watts x 1 Channel and
Signal-To-Noise Ratio (1 Watt) 75 dB
CEA-2006 Secondary Ratings RMS Power @ 2 Ω 600 Watts x 1 Channel and
THD+Noise (Distortion) (1Watt)
Frequency Response (-3dB) 20Hz-200Hz
Maximum Input Signal 5V
Maximum Sensitivity 100mV
Non-CEA Specifications Max Power 1,800 Watts
Low Level Input
Hi-Level Input w/ Smart Engage Auto Turn-on
Low-Pass Crossover 40Hz-200Hz, 24dB
SubSonic Filter 30Hz, 12dB/oct
Thunder EQ 0-18dB, Freq. 40Hz
Remote Level Control Subwoofer (Parallelable)
DIMENSIONS Length 14-5/8"
Width 9-7/8"
Height 2-3/8"
with one of these
Specs:
Model Bravox E2K 12
12" Subwoofer
Dual 4 Ω
RMS power 700
Max power 1400
Specs:
Bass Boost Circuit
2 Ohm Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Soft Turn On/Off
S/N Ratio: 90 dB
with two of these:
Specs:
Model T5512-44
12" Subwoofer
Dual 4 Ω
30 - 150Hz
RMS power 300
Or, this:
Specs:
# of Channels 1
Class D
Full Range
Low Level Input
Width 9-7/8"
Height 2-3/8"
with one of these
Specs:
Model Bravox E2K 12
12" Subwoofer
Dual 4 Ω
RMS power 700
Max power 1400
