two batterys how to fuse them
are saying fuse from your front bat to your rear or fuse between your 2 rear bats.
in example A. fuse close to your front battery and then anouther fuse close to your rear battery. from your rear battery you shouldnt need a fuse to your amp.
example B. just make sure your fused like in example A. you dont need a fuse inbetween your rear batteries
in any case if your unsure, Just make sure theres a fuse between each power wire, so if somthing happend between the rear and front bat, the fuse would blow, and if somthing happend between the amp and rear bat, the fuse would blow, so in any situation, just make sure all power wire is fused like lets say the main bat is under the hood, there would be a fuse there close to the battery, then if u have another wire back to the other bat, and a wire to the amp, there would need to be a fuse between the other bat and amp
fatboyracing
fatboyracing
Owensboro KY
standbackimapro
