Two 8'' W7's or Four 6.5'' W3v3's???
all the hd 800/5 is a 500/1 and 300/4 in one case no real benifit in it specially at the price man
Crossovers are much better on the 300/4 than the 800/5. I believe the 800/5 does not have the frequency multiplier switch for the front channels. You would need an external crossover if you wanted to run the front 4 actively crossed....Not that this has anything to do with the sub channel. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
As far as subwoofer setup here is my 2 cents...
6w3:
surface area=17.36 sq in(x4)=69.44 sq in
69.44 sq in times 8.89mm(xmax)=617.32 one way volume displaced.
8w7:
surface area=38 sq in(x2)=76 sq in
76 sq in times 19mm(xmax)=1444 one way volume displaced.
A difference of 826.68 on EACH end of the stroke, total displacement differnce of 1653.36. More than twice the out put of the 6w3s. As far as power goes either amp will do quite well with both setups.
Sideways17
Sideways17
Franklin Grove, IL
Sideways17
