Two 18s, 300 amp alt, 2 batts, big 3, REBUILD!
Fi BL 18z in box with kicker 2500.1 SOLD so goin with a new setup hopefully louder then the 18z (144.4dB on TL on music)
Equipment goin in as of now
EA 300 amp Alt
Shok 1/0 gauge and Big 3
Stinger digital voltmeter
C&D 134ah
Still unsure of what substage goin with but open for ideas...stay tuned for progress
Ya i just wanted to do it to say i did it...and it did sound pretty bad ass at the same time...but i think im gonna try to shoot for 147ish on TL i was lookin around 2500-3500 rms range
4 12s would be another option. I think you would have a better chance doing 147+ with that since there is more cone area than 2 15s. I mean, 15s would most likely beat out the 2 18s but I think only by a db or two on that power.
Those 15s are going to be in way too small of an enclosure. I just don't see 4 15s in ~10 cu ft working out too well. I barely have enough airspace for my 2 SDC2.5 15s, let alone 4! Why not go with some subwoofers you can put in the correct size enclosure? I bet you will get better results that way.
Shok 0/1 ground
knu triple 1/0 batt terminals on new red top.
just a little overlook of engine no big 3 or alt in yet
all wires through
The C&D and rack are next
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
198
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
170
ABMughma
Under Construction
ABMughma
INDIANA BOI
Bad4health
