Two 10 SD2.5 Box Help***
williambrea
DD>AQ
I am doing these in a trunk of an AQ1200d
I am using this box design
http://img30.imageshack.us/my.php?image=35cubes30hz465sqin0cb.png
I am just wondering what tuning these woofers like to be tuned to?
The Fs is 33 hertz but the website says to tune to 40 hertz.
I was thinking around 1.5 cubes per sub tuned to 32hertz with 14sq inches of port area per cube.
Opinions and comments are welcome!
Thanks,
William
i tuned to 38 with my box and i'm very happy with it. The owner of AQ (DJL on this forum) recommends a tuning frequency of 38-40 for these subs as well as the HDCs
Okay Im going to tune to 38 hertz with two 4inch aeros, with a 3.2 cubes net.......
FORGET THE ABOVE DIAGRAM
does the airspace sound okay?
i cannot seem to find their box recommendations on their website //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
two 4 in aeros should work well, although i would recommend a single 6" if you can, will cause less air turbulence that way and would be around the same port area. Both should work well though...
airspace seems to be about right, maybe a tad on the large side, but with how much power your using i think it will work well:
http://www.audioque.com/aq/whatSubs.htm
4th paragraph lists box sizes. You can also go to the digital designs website as well since their box recommendations are very similar to AQs recommendations.
Im going for teh lows, but im not really increasing the volume much... Just want to make sure it will drop low //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks for the link!
I think AQ's website needs a makeover like the new DD website //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
ya, everything else seems to be easy to get to on the website except box info.
although, it would be nice to be able to find out the prices in the sub info sections, instead of just on the order form...
williambrea
DD>AQ
williambrea
Roanoke VA
Digital Designs
