Tubes.....and the Jerks that use them.
Get a SS amp with high clipping headroomand install 'DSP' to mimick your tube amp distortion sonic signature vs. spending
big dollars on tube amps with esoteric components.
But...that's...not...the...point. I'm not saying there's justification for really, really high priced components, but IMO, there's something an amplifier with under 10 parts in the entire signal chain offers that no combination of SS parts does. Yes, you can make them sound identical, but is it the same? Well, that answer depends on your own perspective //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
when there is a simple pathway.
Simple pathway? DSP isn't so simple from a technical standpoint, that's for sure //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif An analog front end driving a SET output stage is as simple and minimalistic as it gets.
Good transformers are hard to find, and EXPENSIVE...
Yup //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Especially good air gapped ones...
^Agreed.... Pretty much all around.....
That's the branch on the Audiophile tree that Jim and I have in common. I'm all about: simple path = pure reproduction of sound. Whether it is a fools view of audio or not; I do not know, but it's been working well for me that way //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Think outside the speaker box. Get a SS amp with high clipping headroomand install 'DSP' to mimick your tube amp distortion sonic signature vs. spending
big dollars on tube amps with esoteric components. People frown upon this
because they feel cheated when there is a simple pathway. There is no
benefit from a marketing point of view -> why sell a SS DSP amp for $500
when they know people will buy the $20k esoteric tube amp. lol
Because, among others, the musical instrument industry has proven that NO DSP available now, actually sounds EXACTLY like a tube amp.
Seen many a studio pro... recording engineers, etc... marvel at all the crap people buy to EMULATE a tube amp... when they usually could just BUY one in the first place, and save all the time and trouble. Apparently, time wasted isn't worth money, to some people...
Regards,
Gordon.
Yes I agree. This is what I always have learned too! Signal Path FTW!
Regards,
Gordon.
That seems rather obvious but people don't get it. Same reason some bands still tour with B3 Pianos with REAL Leslies.... Nothing sounds like them even though they have tried....
1. DSP's have been used for a long time to create musical instrument sounds
more complicated that tube amp distortion. Don't underestimate digital effects.
I have a $300 guitar amp with DSP that mimicks certain Marshall, Fender, Mesa Boogie, etc., tube amps;
12 different amps in DSP with from clean to distorted tones. I'm sure you can get better DSP's in higher end gear.
2. I can see where a studio would want tube gear to add distortion to
the recording mix, but I was thinking that the performer {ie guitar player}
would use his own gear to generate a specific tone, otherwise there is
no advantage to tube circuits for making recordings unless you want to add
tube amp distortion special effects. I'm sure someone wants this so it exists.
3. There is no proof in audio that a short or minimalist signal path = best SQ.
Do you see a mimimal signal path here; http://www.atlserver.net/d/10296-2/100_0183.jpg
Why is it ok to have a huge signal path when recording your source material
but all of a sudden, it's bad if you have one for playback? If it was bad, then
your source would be poor. There are poor recording and the root cause of
the recording can be attributed to many issues.
4. In a previous post it was said that a certain tube has the best linear
performance of any electronic device implying that this is mandatory in audio
design. On the other hand, lets look at Nelson Pass and his designs. He likes
to use vertical mosfet transistors, one of the worse kind for audio if you examine
it's linear performance. Point is, a quality amplifier is judged by it's complete design, not
by a single component that is good. The best component in the world won't make your
amplifier work if it's not designed well.
5. If you listened to a musical instrument live and like the sound, then why would you
want to add 'more coloration' to the natural sound of the instrument? There is no tubes
in acoustical guitars, saxaphones, pianos, etc. lol
I bet they didn't ABX the test, lol... and did they try to dupe all the tube amps in the world? What I mean is, not every tube amp design
will have the same overload performance so if you try to mimick a tube amp via DSP, which ones were chosen? lol ..
It's also nice to learn the truth about audio in spite that you may have
personal preferences. I have preferences - just because - , but I know
the audible effects, if any for each case. It's nice to educate yourself to know
the issues.
I've done D/A to ADC tests where I sabotaged the signal path by
doing extra extra converstions vs. digital pathway up to the audio amp.
Result: nobody can tell the difference. Not only is the signal path much longer,
the signal is being 'hacked' to bits {pun} many times over. lol
This is funny because many people in the audio world insist they need
external 'special' DAC's, they insist that only 1 conversion is done, but
I know these people would fail a blind test because nobody has ears
as good as test equipment.
An interesting blind test would be MP3 vs. uncompressed audio.
At what bit rate do people start to hear a difference? They will fail at
some compression rate. If compressed music is not audible, then why
would a pure signal taking a long path be audible ?
1)My ear is my proof //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
2)It's not ok, that's why 95% of all pop recordings sound like crap //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
* Unless your test is controlled, it's just a gut feeling.
* You bought almost every pop music CD to examine ?
I could be wrong, but I don't think pop music is engineered for SQ as the
the main objective, that market is more interested in other aspects of the sound.
Honestly if I hear another person "QUOTE" or mention an ABX test I am going to drive to their house and put a soldering iron in both of their ears. Then I’m going to break their fingers so that they can’t type this CRAP anymore.... It's seriously the lamest excuse anyone has ever come up with why something isn't better than something else. Hearing is subjective get over it!!! I know I know you are going to say they are designed to find if two things actually do sound worlds different, well I leave it at that. But, think about the exact terms of what the test is testing and what we are actually buying, listening to, and watching. If I go to the store and listen to something with special cables, power condition, different CD Players, different Amps, TUBES, NO TUBES, and I like something and I buy it, its because it had something that caught my eye or ear rather. What I am trying to say is you can spout off all the technical jargon you want all day everyday, but it comes down to what people like, ABX or NO ABX. If you live in a world where you believe that everything has to be and pass an ABX test to go into your system well then I am happy for you, but I don’t want your system. I’m happy with my own which probably wouldn’t pass your ABX testing on several levels. However, I would almost guaranty you with 100% certainty that most people could tell the difference between something like a REAL B3 with a Leslie and a synthesized one. Oh and DSP “effect” boxes sound like balls....
Do you know who I am?
.. I'm the Juggernaut B*tch!.......... your soldering irons can't hurt me....
.... I'm gunna hit you with your own pimped tube amp .....
Beat_Dominator
Yea, thats Mecha Godzilla
Beat_Dominator
Phoenix Arizona
Beat_Dominator
