Truck install ???'s
  • 3
Well this site is the cheapest wealth of information I know of, post all your questions under the certain forums they fall under and you'll get replies - also the Eatel site(which I dont have the link for right now) is also helpful for the new guys.
Try looking around for that Eatel site in the meantine.
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
4
350
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
8
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
Hurst421
Hurst421
Hershey,PA
ss3079
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
