Too Much Port Area??? (8" Port, 3 Cubic FT)
Not sure how you're doing your math, but something's not adding up correctly. If you just jam a 8" x 33" tube in a 3 cube box, you're lookin' at under 2 cubes and over 40hz. And the displacement is WAY more than .029 on a port that size. That's about a cube alone.. So to answer your question. That's around 25" of port per cube. That's a LOT. In the 'too much' range..
I was hoping to do something like this but down the side of the enclosure
I guess i'll do external...
Wow.. That port is choking. Far to close to box wall.
True but if I inserted it through the side I would give it more room from the port wall.
Seeing that having the port internal will bring me down to 2cubes i'm going to go another route...
Thanks for your help
Just do one 6" port. Mount it to a 3/4" MDF circle from inside the box with a total length of about 17.5". That should leave you with 3 cubes @ 34hz with just over 28" of port area. It's not a huge amount of port area but it's over the minimum 'rule of thumb' for aero's.. Aero's don't need as much area as slots, squares, etc.
Last resort i'll go this route.. thanks for crunching those #'s for me
Might just build a box 4cubic ft. with the one 8" aero and subs inverted to give me about 3cubes net.
Mr.SoloDolo
Mr.SoloDolo
Marin County, Ca
bgowdy
